Hi all,
my e-220 CDi - 2002 (w211) is having problems starting up. It takes quite a few turns to start up and that too it start rough. once started it is fine - no extra noise no misfire no leaking injectors. But quite slow of the line. I have to wait once I press the accelerator to get it to go from the lights. After that its fine.
According to my mechanic one of the injectors needs changing - possibility? also, I do have a set of injectors with me with the part # A611 070 16 87 - while my car has injectors with the part # A611 070 11 87 - do you think they will work intechangebly? I dont want to go buy a new injector (which is quite expensive here in Pakistan) if this is not the case.
I was going to try changing the injector but i've read a few horror stories on the forums so decided not to risk it until someone here helps me out or pumps up my confidence
Thanks,
Usman
Thanks,
Usman
