PlasT0R
Hello ,hope you all well.
Unfortunatley ,i've notice another sound and i hope is not the gearbox.
While driving between 20mph and 40 mph ,that is on 3rd gear to 5th gear i hear a clicking noise, as soon as i'm speeding up can't hear it anymore.
I don't know exactly how other cars perform when changing the gears ,but mine jarring a bit when changing between 3rd to 5th. It could be the torque convertor?
If i press the kickdown the gears are really smooth ,can't even feel them change which is wierd compared driving with 30 to 45 mph.
On idle mode the clicking noise is not present, when i disengage the gearbox from the engine while driving the clicking noise is not present either. When i switch the gear from P to D is start moving so i don't see that the torque convertor is bad ,i cannot figure it out.
The clicking noise is louder when driving next to a wall with that speed .
Any ideas what it might be from your experience?
Forgot to mention that when kickdown from 4th gear to 5th gear,4th gear goes up to 4500rpms and then is the gearbox changes to 5th.
