E class ashtray removal (W211).
Discussion in 'Interior' started by B3RJO, Sep 15, 2008.
  1. B3RJO
    B3RJO New Member
    8
    Sep 12, 2008
    Car:
    2008 E280cdi sport
    I need to remove either the front or rear ashtray in my 2008 E280cdi auto in order to gain access to the wiring on either of the cigarette lighters. I want to hardwire a sat nav.
    Does anyone have instructions to do this? The wiring is not my concern, just the physical removal of trim to access the rear of the sockets.
    Any help and advice appreciated.
    Roger.
  2. Gollom
    Gollom Hardcore MB Enthusiast
    4,227
    May 10, 2006
    Preston, Lancs
    Car:
    S211 E220CDi AvantGarde, NTG 2.5 with Linguatronic
    Welcome!
    I don't have it to hand, but if you do a search on this forum it has been covered a number of times.
    Very easy to do - even I managed it! :eek:
  3. Alfie
    Alfie Authorised Forum Sponsor Authorised Forum Sponsor
    7,765
    May 5, 2004
    Surrey/Cotswolds
    Car:
    W169 A, W205 C, W451 smart
    Put the car into drive and then turn the car off. This moves the gear selector out of the way.
    Prise up the gear selector surround with a plastic wedge.
    Pull up the wood/aluminium trim. It can be quite stiff. It is held in with clips thats all. This exposes the front of the ash tray. Carefully prise the two plastic clips away from the front towards the back of the car. This unlatches the ashtray. It then simply slides out revealing the wiring. Five minutes tops....
    stephenmercedes likes this.
  4. OP
    OP
    B3RJO
    B3RJO New Member
    8
    Sep 12, 2008
    Car:
    2008 E280cdi sport
    clarification.....
    The gear lever is in a sort of oval panel (wood) with a chrome trim and it encompases the C/M/S switch, set into a larger panel. Do I prise up the inner panel first then the outer one?
    Bit worried something will snap.....
    Roger.
  5. SL300-24
    SL300-24 Hardcore MB Enthusiast
    1,722
    May 28, 2004
    Essex
    Car:
    2007 CLS 320CDI,1984 500SL, 2007 E320 CDI Sport Estate, 1993 E320 Cabriolet sportline
    Roger,
    Why not pick up the power freom the fuse box on the end of the dash (driver side)?
  6. Alfie
    7,765
    May 5, 2004
    Surrey/Cotswolds
    Car:
    Inner panel first. Carefully ease it up round the edge.
    You will be very unlucky to snap anything. It is all made to clip together.
  7. Dec
    Dec Hardcore MB Enthusiast
    4,475
    Jul 28, 2004
    Car:
    C180,A.
  8. OP
    OP
    B3RJO
    B3RJO New Member
    8
    Sep 12, 2008
    Car:
    2008 E280cdi sport
    Thanks everyone.
    Job done......just needed to be a bit brave, didn't want to break anything.
    Thanks again,
    Roger.
    markjay likes this.
  9. rosie5golf
    rosie5golf Active Member
    65
    Mar 24, 2015
    Norfolk
    Car:
    Mercedes e320 avant-garde estate
    Can you tell me what fuse to use Roger please. I want to use a piggy back fuse holder rather than pull out the ash tray.
  10. WOODYTHEWISE
    WOODYTHEWISE Hardcore MB Enthusiast
    3,768
    Jul 21, 2011
    E AYRSHIRE
    Car:
    E 500 Coupe.
    Hi. The thread is 10 years old. You may however still receive an answer, possibly not from Roger. I am sure someone will be able to help.
Share This Page
