Had an issue with my W212 estate with "auxiliary battery malfunction".
This stopped the ECO function working (maybe no bad thing!) and sometimes stopped the "HOLD" function operating.
On my version this battery is located in the boot next to the spare wheel. It is reported to be in other locations depending on the model of the car, so you will need to check carefully.
This battery is about £80 from Mercedes. However, it turns out it is a motorcycle battery equivalent and available from many sources eg Ebay for about £40 (or less with a bit of pfaff)
One that is compatible is the YTX14-BS available from many manufacturers. I got one and it dropped straight in and solved the problem. Hopefully this will save some people some money as it appears to be a common problem.
Not sure how cost effective this start stop business will be if you have to replace a battery every 3 years to keep it working. How much CO2 is released in making a battery?
