You would be a lot braver than me to try that!Untimely, I guess the way to do it is to disconnect the battery when the roof is half open.
Most definitely powering itself back into the closed position.Are you sure it’s not the weight of the roof closing itself ?
I think I'll hold off with that option . It's going in to a main dealer at the end of the month for an assessment as one of the headlining tensioner cables has become detached. Others are frayed. I'm in "consultation" with the BMW dealer I bought the car from in Jan this year.You would be a lot braver than me to try that!
Thank you. That appears to work. Long enough for me to see a number of broken cords.On our cab (A238 2019 model) I just press the starter button twice so that all the dash lights are on and then open the roof half way (or as far as I need to clean the shuts or silicon grease the seals. It will stay vertical for a good 10 to 15 mins if you need to.
