I don't know if anyone can shed any light on this problem with W213 widescreen COMAND. Windscreen had a crack and was replaced by MB main Dealer (at cost of nearly £700).
After this, the COMAND is not fully working - after entering a destination the time does not count down as you drive to the destination, the middle navigation display (in front of the driver between the dials) is frozen on the first road that you depart from and the blue route is not updated properly. The triangle that shows the vehicle position does correctly locate at the position of the car. Not tested if the voice instructions work properly.
It is under warranty so it is not too relevant whether the process of replacing the window broke the sat nav or if it is just a coincidence (the dealer has instinctively denied responsibility). Date for workshop is two weeks away, so if anyone has any ideas or if there is a user re-set that I can do in the meantime this would be appreciated.
Has anyone else seen this problem? Any thoughts or comments welcome.
EnEm
EnEm
