Hi guys! I bought my car at 6k miles and I always had body roll and drive straight issues since then. I thought it's due to wheel alignment, so I had an alignment done recently.
I'm sharing the alignment report with you below and I need your opinion. I'm wondering if they did alignment wrong because my car is AMG line estate with lowered suspension and air the suspension at the back, but at top of the report it's written sedan with standard suspension. Do the values in the report look ok? What should they change? I'm currently having the issues:
- Steering wheel tilts left if I let go of it while driving and the car goes left.
- Steering wheel feels loose. Like, if I hold the steering wheel 5-10 degrees to the right or 5-10 degrees to the left, there's no reaction from the car. It keeps going straight and there's no resistance from the steering wheel at all. I need to turn it more in order to get the car going the side I want. This began happening only after this alignment was done.
- Body roll slightly improved after this alignment but it's still there.
- First image is before alignment, second one is after. Thank you!
