E class long whining noise on switch off
rascalmaster
harwich, essex. UK
Brabus D5 (E280 CDI) Avantgarde, E280 CDI Sport Estate, E320 Avantgarde now sold
my W211 E280 CDI (facelift) emits a whirring/ whining noise a bit like an electric drill/ screwdriver, when i switch the engine off.
:dk:
this noise lasts about 10- 20 seconds and stops with a sound like a click.
it can be heard from outside the car, and emanates from the engine bay.
unable to locate the exact source in the the engine bay... :eek:
any ideas?
could it be the inlet port shut off motor?
any other ideas?
thanks in advance!
D
Deleted member 37751
Guest
My V6 320 does this same thing.
I'm not worried in the slightest. These engines are smothered that much in electrics, it will be some obscure machine turning itself off.
I'd start worrying when it stops making the noise....
OP
OP
R
rascalmaster
harwich, essex. UK
wonder if anyone else has noticed and can corroborate this...
prm
Braintree Essex
Ml350 bluetec 13
Yep, same thing with my e280cdi. Always thought it was the turbo spooling down.
OP
OP
R
rascalmaster
harwich, essex. UK
Yeah as the car makes the same noise even if left idling for a while before switching off; I think the turbo should have stopped by then...
OP
OP
R
rascalmaster
harwich, essex. UK
the whirring/ whining stops with a click/clunk noise...
so i'm thinking maybe something mechanical. whats mechanical that works for a bit after the engine's stopped?...
-brakes?
-AC (though i'm sure mine's done it even when i have not used the AC)?
-inlet port shut off motor?
i must say, not too worried; as you all have noticed the same so it's obviously business as usual for the W211... now i'm just curious. lol
Benzowner
Bristol
Qashqai Acenta Premium 1.6Diesel
Could be the engine cooling fan which activates with the aircon/climate control. Turn off the climate control and it should stop the noise. If it gets too loud, the bearing are on the way out with a potential bill of about £600:(
OP
OP
R
rascalmaster
harwich, essex. UK
ok.. will try again today ;-)
the noise only seems to come 'on' when the engine is switched off though.... and lasts for 10 seconds or so, before 'switching off' with a click.
tom270
E270 CDI
hi,
i think this noise will be the sbc brake pump resetting itself
tom
Dryce
I have a non-turbo petrol with SBC and it doesn't do this.
So more likely cooling or valve or fan (again cooling) related.
Monkeylegend
2015 F10 528i BMW, 2011 Citroen C3 Picasso, 2009 Ford C Max.
Mine does this, it is definitely the cooling fan on mine,and seems to be noisier and takes longer to stop after switch off depending on the load on the A/C.
I had mine checked out by my local dealer because it would also come on sometimes as soon as I switched the engine on first thing on the morning for example. They told me the cooling fan was designed to run at lower speeds ie 50% ? capacity,( can't remember the exact figure ) even when the car was cold. Not sure how true this is.
They said it was nothing to worry about, and so far they have been correct over many miles.
