E Class protective plate on front wheel
bodycoat
He plates have come loose on the front wheels behind the brake system. I presume that I can add a washer each side of the plate to secure it again.
Does anybody know what size washers I will need?
What on earth are you talking about - suggest you take a pic of the problem and then maybe someone on the forum could help you:crazy:
It will probably be the dust shield. No idea what the problem with it is, but if a washer will fix it and you don't have the right size then nip down to your local hardware shop whilst the wheel is off. Job done.
