E200 Kompressor failed emissions
TheBanjoman
ireland
Ford Focus
Hi
i have a e200 2005 komp
failed emissions
I had one fault lambda sensor, I replaced this everything seemed fine
FIRST TEST
Low idle
CO0.67% Above 30% Result Failed
High Idle
(3.000rpm) CO.065 VOL% ABOVE 0.20% RESULT FAIL
NEXT TEST (REPLACED LAMBA SENSOR)
HIGH IDLE
CO 0.04% ABOVE 0.30% RESULT PASS
LOW IDLE
CO.041 VOL% ABOVE 0.20% RESULT FAIL
So lamba brought down high idle to near perfect it also brought down low idle from 0.65 to 0.41%
any suggestions? please
If the car wasn't fully warmed up when tested? I'm speculating, but higher temperature of catalytic converter will help imho
it drove 10km to test centre im sure thats good enough?
Unless its got a faulty thermostat which delays warm up time- i. e.its open all the time? Normally they should check the engine oil temperature with a probe thro the dip stick tube for the test- might be worth checking on the mot report?
I have attached the two Nct reports in the first post
Oil temperature in
First
92%
Second
110%
Would replacing the 2nd lambda sensor sort this?
Would the cat be dirty considering the engine would of been running rich due to the 1st lambs sensor being faulty. maybe a cat a clean
I've not scrutinised all the numbers - but definitely 'rich'?
Unburned fuel can get to the cat if running lean and there is a misfire or incomplete burning. Cat will take a (thermal) hiding in that scenario and can burn out.
Not sure about the rich scenario - maybe the chemical action of the cat creates heat enough to burn it also (even though no oxygen - unless a misfire is present).
Hi thanks for the reply,
I have changed both lambda sensors
Put in a cataclean additive
Engine flush followed by a oil change with filter
Also added a stop smoke additive
Any ideas if this w211 e200 1.8 kompressor has a pcv valve and location?
Depends on what kind of driving occurred in those 10km. If all/most was low speed stop and go, then the car was not warm enough.
Usually a 20km trip at highways speeds works best. Drive directly to the inspection station after that and leave the car idling if possible.
