colin.dillon
Hi everyone
Was wondering if anyone could shed some light on my window problem - every now and again the driver's window doesn't work. Over the month by trial & error I've found that if I disconnect the battery, operate all the window switches, reconnect the battery everything works fine 'till next time. If I just disconnect the battery, wait a few minutes & then reconnect then sometimes no windows work, or just the back don't or any combination you can think of! My feeling is that operating the switches must drain some residual current somewhere which then resets something! I assume there's an electronic control module somewhere? & this needs replacing. Any ideas on where to look or any other pointers?
Thanks in advance
Col
Thanks in advance
Col
