markheaney2
has anyone else experienced a fluttering banging noise from the rear of their 211 i have so far chiselled the front bushes of the subframe out it was not like a 210 it took 3 hours i think the rear subframe bushes are soft and allowing the subframe to bang on the floor the thought of chiselling the rears out fills me with dread they are 30 percent bigger than the fronts i have tried to buy a subframe bush removing tool to no avail lots available for the 210 only one available for the 211 is mercedes own at 510 pounds anyway has anyone else got this banging fluttering noise i have replaced shockers springs trailing arm bushes had it in to mercedes for a full rear suspension check they cannot find anything with any play whatsoever because this is a taxi in the centre of york it is doing my head in it sounds just like the exhausts is banging on the floor when you hit a sharp bump or rut in the road any suggestions before i park the car up permanently
