Hi all - new here and joined to scan through information to try and find an answer to my sons E220 which is currently a none starter.
Car was operating fine with no problems but he pulled into services for a cuppa stop and then car wouldn't start. We had to have it recovered to his home and I took a look at it.
On close inspection it had the Black Death problem and it looked like all but one injector needed reseating - so I ordered parts to do them all. Before that I checked fault codes with a basic reader and the only fault visible was "Camshaft Position Sensor" so ordered a replacement at the same time.
Cleaned and replaced the injectors and recut the seats - with new bolts and copper washers - all torqued down to spec and that repair is sound (had to replace a Delphi injector connector plug because the carbon had made it go brittle from the black death). Once back together i also changed the camshaft sensor.
Unfortunately the car still will not start - even with Easy Start - it does every now and again get a small sign of life like it is going to run but it literally is for a split second and then it stops.
Tried so far:
Fuel is to rail (admittedly not sure on pressure)
Fuel pump fuse is good
Fuel pump relay (tried eliminating this by bridging the connections as shown in a previous post)
Checked OBD status again and still comes up with Camshaft sensor but i can now clear it which I couldnt before - it also doesnt come up on every attempted start.
Tempted to change the Crankshaft Sensor but cannot find a way to get to it - I think it is on bell housing at rear of engine but cannot find a way to get to it from above or below.
Any advice would be gratefully accepted - i am searching for an Indy in Sheffield to take it to because I feel i have exhausted my technical ability.
regards
Richard.
Tried so far:
regards
Richard.
