Hello
we have a e class e220 2002 in the family and it is giving out a lot of white/grey smoke.
the smoke starts as soon as you start the car and gets worse as the car warms up
coolant hasn't moved an inch
we had it diagnosed by the following
merc specialist : he said star is saying your turbo has gone
a local mechanic : we serviced the car (oil change) and the smoke decreased for a few weeks, they said it might be your injectors
RAC : it maybe your injectors
another merc specialist : not sure what it could be as test on injectors is fine only one seems high
another local mechanic : its your inlet manifold flaps/motor, he spent some time and said 120% Certainty its the flaps.
so we are in a position where we are looking at a new manifold, manifold flaps or a new manifold motor
can anyone help give us any input to what would happen if we were to leave the flaps open
i have seen a manifold on ebay where the flaps are removed and the holes professionally sealed, i have not idea what that even means, what holes ?
the description says as follows :
"Item is in used, good condition with flap motors removed and their holes professionally sealed off! You will never have to change the manifold again!"
attached is a picture of the sealed holes
any advice would be appreciated
thank you in advance
