MichaelE211
Need to replace brake pads, other than MB replacements, what make do other fit, and what is the average cost you guys pay (per set of FR & RR).
Satch said:If you have not already done so, suggest you read this carefully if you car is fitted with SBS. I presume this will be DIY job.
http://mbclub.co.uk/forums/showthread.php?t=20676&highlight=w211
If I had to change pads would think seriously about these:
http://www.europerformance.co.uk/pages/products/product_info.mhtml?id=83078
Satch said:They may also want to change the rotors as well, since some modern cars seem to eat these at roughly the same rate as pads.
How many miles has this car done?
AMGBoy said:have you tryed a MB dealer for the parts
ive changed lots of pads and dics on 211's
as long as the discs are not below the min thickness you might only need the pads if you need any more help pm me
thanks
Brian WH said:If you value your SAFETY I would not use other than Genuine MB Pads.
It may be Too Late to be wise after the event mate.
