E240 gear problem?
Discussion in 'Engine' started by Charles.Y, Oct 8, 2008.
  1. Charles.Y
    Charles.Y Member
    51
    Jan 26, 2007
    My E240 auto (1998 model) recently sometimes after starting the car will hold on to the 1st gear and will not change up. I noticed that the rpm is near 5000 at about 20 mph. When I stopped the car and restarted engine, the problem is gone. Is it something serious please advice.
    MAF sensor? Gearbox? etc
  2. nickcc101
    nickcc101 Hardcore MB Enthusiast
    355
    Aug 4, 2007
    Helston Cornwall
    Car:
    2001 S203 C180 auto estate (sold)
    Check the oil level if you have a dipstick, if not you can buy one from ebay for about £20, or take to indie or Mercedes. Oil and filter should be changed about 50k miles. If you say whereabouts you live then another member will probably lend you a dipstick.
  3. OP
    OP
    Charles.Y
    Charles.Y Member
    51
    Jan 26, 2007
    It was lasted serviced 12 months ago and the service is not due for another 5000 miles. Is it the oil level low - I will check.
  4. OP
    OP
    Charles.Y
    Charles.Y Member
    51
    Jan 26, 2007
    Just checked the oil level which is fine (right at max). Please advice any other causes.
  5. nickcc101
    355
    Aug 4, 2007
    Helston Cornwall
    Car:
    As long as you have checked the auto transmission oil level (i would have thought that you would have had a sealed diptube without a dipstick though) then you need to find out when the transmission oil and filter were changed. If it is the original and your cars mileage is in the eighty thousand region or higher then i would suggest changing the auto transmission oil and filter first. This will be a far cheaper option before taking into indie or Mercedes. If this fails to cure the problem then you need advice (Star computer) from indie or mercedes. Make sure you are using the correct diptube and not the engine oil. Auto transmission oil is not changed, unless requested on a normal service, as it was supposed to be filled for life. This has now been proven to be incorrect advice.
  6. OP
    OP
    Charles.Y
    Charles.Y Member
    51
    Jan 26, 2007
    Hi nickcc101,
    Thanks for the info. My car has always been serviced by authorised MB garage (and it has done 80k miles) and I always thought that they will (as an expert) take appropriate action to change the fluid thru routine services which is apparently not.
  7. nickcc101
    355
    Aug 4, 2007
    Helston Cornwall
    Car:
    Hello Charles.Y
    No they don't change transmission oil unless requested as Mercedes state that the oil should last the life of the car. I changed my Auto transmission oil and filter at 83000 miles after i started to loose drive and also found the gearchange very jerky. This solved my problem. The oil costs app £11 per litre and the filter with gasket about £12. The max oil you should require is 7 litres. There are plenty of first rate threads on the Forum with all the information you will need if you are intending to do this job yourself. All the information that i have, re this subject, has been learned off this forum.
  8. maher
    maher New Member
    5
    Mar 8, 2009
    Harrow
    Car:
    E240 elegance
    Hi all, I am new to this, I got a E240 Elegance 1998 Auto 80K on the clock,
    the first problem was that i did not have any drive at all, or reverse, i changed the filter and the ATF now i have drive and Reverse but the car will not change up a gear, cold or worm, it will not change gears, i tryed swiching it of and on, did not help, any advice,
    and one more thing how much ATF is needed, and dose any one near harrow have a dipstick that i can use to check the levle.
    many thanks
  9. welland99
    welland99 Hardcore MB Enthusiast
    694
    Feb 26, 2009
    Malvern
    Car:
    W210 E280 estate 1999 facelift; 6th gen honda accord coupe 2000
    Can you change gear into second by moving the gear lever to 2?
  10. welland99
    694
    Feb 26, 2009
    Malvern
    Car:
    Can damage be done to the gearbox if the oil is not changed until it misbehaves? I mean is there any real advantage to changing the gearbox oil if the gearbox is working fine?
  11. lynall
    lynall Hardcore MB Enthusiast
    3,169
    Jul 31, 2008
    Kent
    Car:
    The silver one.
    I would say you change your engine oil to prolong the life of the engine so do the same for the gearbox.
    My favourite saying is oil is cheap and engines and gearboxs are not!
    Lynall
  12. BlackC55
    BlackC55 Authorised Forum Sponsor Authorised Forum Sponsor
    18,803
    Feb 8, 2007
    Horndean, Portsmouth, Hampshire, Southsea
    Car:
    C43 AMG with a 55 engine and supercharger, E55 AMG, S500, etc
    It is VERY important to get the ATF changed.
  13. welland99
    694
    Feb 26, 2009
    Malvern
    Car:
    Well that makes it seem even stranger that MB say there is no need to change the oil ever. Some have written that it should be changed at 80k miles, but look at how many people run these cars into the multiple hundreds of thousand miles. What were MB thinking of?
  14. compress ignite
    compress ignite Hardcore MB Enthusiast
    208
    Jun 4, 2006
    32 degrees North by 81 degrees West
    Car:
    '90 300D 2.5
    SOMEONE (In Stuttgart,Maybe?) wasn't thinking...
    "They"were listening to silly "bean counters"or "merchandising specialists"
    instead of the "Engineers".
    I still cannot believe ANYONE fell for this ridiculous scheme.
    (at MB or the public)
    MB has been making autos for over 100 years,THEY know Better!
    The only way I'm not changing fluids (At the extreme service intervals...
    normal in town driving) is upon direct command of the Almighty...AND last
    I was informed there is no hope of communication from that quarter on this
    subject.
Tags:
Share This Page
