E250 gearbox oil change and chain
Discussion in 'Parts, Maintenance & Servicing' started by Eduard, Sep 10, 2018.
  1. Eduard
    Eduard New Member
    8
    Apr 4, 2018
    Northampton
    Car:
    Mercedes E class W212 59 reg
    Hello, I have a mercedes E250 W212 59 reg, does anyone know for sure when and if the oil changes in the gearbox and if the distribution chain needs to be changed and if so when? Tnx
  2. markjay
    markjay MB Club Veteran
    21,291
    Jun 24, 2008
    London
    Car:
    W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
    Manual gearbox or automatic transmission?
    If automatic, 5 gear or 7 gear?
    The 5 gear automatic is every 4 years / ca 40k miles.
    The early 7 gear automatic is every 3 years / ca 35k miles.
    (Some cars say 'sealed for life', or 'change once at...', but in either case you can ignore that).
    Also it is recommended to change the entire ATF i.e. including the ATF in the torque converter and heat exchanger.
    As for the poly belt / serpentine belt, it is changed on condition, i.e. there isn't a fixed change interval for it.
Share This Page
