timtjohnson
On two separate occasions in the last month my E280 CDI (V6) has hesitated and then lost power when I have kicked down asking for some rapid acceleration. On both occasions the engine was fairly cold. The car then went into limp mode BUT with no warning light on the dash.
After pulling over and restarting everything appeared normal, including rapid acceleration.
On the first occurrence I had the Mercedes dealer look at the stored fault codes. They replaced the lambda sensor that was giving continuous faulty readings. There was also a stored boost pressure sensor fault but they couldn't reproduce despite lengthy tests and they recommended leaving for now.
Does anyone have any thoughts on whether my symptoms could be a faulty boost pressure sensor or whether it's something more sinister such as inlet port shut off motor, or turbo unit. Should I leave this until it develops further and avoid kick down when engine isn't up to temperature? Could dirty air filters cause such symptoms?
Finally, is the boost pressure sensor an easy DIY job that might be worth doing?
