My V6 diesel faults weren't picked up until a couple of months after I bought the car. Bearing issue was spotted by Ollie when I took the car in for what I'd hoped was a simple "health check". Result - £3K repair! Luckily caught during the warranty period and the supplying dealer paid..
Next job was the EGR valve and tensioners, happened about 5 months after buying - £1500 - but again paid by dealer.
Not a great start and has left me feeling down about the car ever since. Hence I'm selling.
Be cautious and avoid if poss.
Edit: And, be wary of the SBC braking. Take a look on other posts about this. Go for 56 at least and you avoid it.
mercgames said:I run an early V6 cdi (320 sport), bought 14months ago with 36k on the clock, currently showing just over 50k.
Touch-wood all ok so far, but still low mileage.
My opinion, first check the turbo seal is not leaking. They have a small lip on the inside which must be fitted properly, ie fully pushed on on over the turbo, also i put a smear (thin) of sealant round the end of the seal, the area with the part numbers on that fits into the plastic housing. I discovered mine was leaking after a service, it was very poorly fitted, and i believe i was luck to catch it in time.
The majority of mileage i have covered is distance, last summer 3k around Europe, and southern Spain at the moment for winter. These engines are superb at eating the miles quickly and without effort, i can top 700 mile range, and have seen 150mph plus....but it would not be my choice for commuting or running for the weekly shop (short runs)....they seem to like a good run/thrash.
I think *** had a poorly fitted part (if my memory is correct) which caused a lot of headache and was not found till later, after a lot of grief. Hopefully his new steed will be better.
best o luck.
mbenz1 said:We have a facelift 2006 (06) E280 V6 CDI (190BHP engine), does that mean it will have the problematic SBC unit installed?
Get a 56 or newer - the facelift cars are much more electrically reliable.
