runningman
- Apr 25, 2014
- 300 td
1998 E300 td, 49700 genuine miles.
Has anybody out there ever replaced the fuel pump advancement/retard timing mechanism, which is located on the back of the pump drive sprocket. As i have a gut feeling that mine has somehow jammed in the retarded position following very (suddenly) bad starting one morning (knocking its head off).
The only way i can stop the diesel knock is to advance the pump by rotating it 2 - 3 mm towards the block.
EVERYTHING regarding the fuel system has either been checked ok or renewed.
Done a liqui moly diesel purge and the engine ran like brand new, until i ran it on normal diesel then the knock returned.
Before i advanced the timing the engine knocked at idle up to 1250 rpm but cleared as the revs increased. No smoke, starts first time but power feels a bit flat.
When i advanced it the knock dissapeared, engine ran smooth as silk, no smoke, starts first time, the lost power has returned and MPG is better.
How easy a job is it to change it? and are the're any pitfalls i should be aware of?
Im very handy with the spanners.
Regards
Regards
