bonez59
Hello, as some of u know that i have had major rattly sound coming from the engine, well found part of the slide rail had snapped off, so thought id change it, started taking it apart and check the timing, put the bolt through the inlet cam, both the little dots lined up but the bottom pulley was reading 22' thought it might read 0,1,2 but dam So take it needs a new one??
The car has paper work saying it had a new chain last year but the way it was coming apart im not so sure. Got all the fan off and rad moved enough to work on the engine,
What else do i need to take off to change the chain and how i lock the diesel pump in place??
Thanks ian finaly getting some where with the dam car.
