Hi to you all. I have had a small fuel leak, so yesterday I changed the fuel shut off o'ring on the fuel pump. I did it about 15 months ago and recently i noticed a smell of Diesel. Anyway the old one had a small nick in it and I have used it and not noticed any more leaks touch wood so far. Anyway Patriot of doom had a how you do which is fantastic just found it. I have decided that its time for me to change the plastic pipes and the 6 o'rings in the injector out lets as per POD's How to do instructions. I have gone through the parts diagrame's and have taken down all the part's I need, But I would Like to know how the Inlet Manifold is removed. Looking at the Diagrame's in the parts book does the manifold just slide off the main pipe Which goes to the Turbo! I noticed a part which I assume is the o'ring sealing It!!!! Is the unit attached to it the EGR is it worth stripping and cleaning, will i need any other parts!
I am not in the UK this is why I am asking, I want to buy all i need to do the job in the next few weeks when i return to the uk.
I appricate everyones advise, and as usaul its all great advise, One thing I can say this fourm is better than going to a dealer.
Thanks Again
Thanks Again
