E300td99 Inlet Manifold
jrggino
Hi All, Can anyone tell me what is connected to the inlet manifold as i have to remove it. Is there a flex hose, will i need new parts if i remove it. I have had a quick look and cannot make out what is connected to it and how to reove what is connected to it. I ask as i am sure someone will tell me that i prob will need to replace a clip or screww. I am not in uk so i will have to plan what i will need, buy all i need and then start the job. So any help is fantastic. I have a fuel leak I think its the pipes but i want to do the o rings in the top of the pump as well. Here in italy everyone is on holiday so want to start the job with everything i may need, as i dont want to leave it stripped because i needed to replace a clip that always breaks LOL. Manythanks to you all
Gino
You have the torx that held it on the head, then the EGR valve pipes under it, its atach to a wee clamp that is a pain to remove or replace back, and under the EGR you have a bolt, you need to go under the car to access it.
I'll see if I can find a picture for you to see :)
You'll need a new gasket for the manifold where it rest on the head and you may as well change the Oring that connect the manifold to the air intake.
