bigbug
- Aug 11, 2016
- m210 e320
2002 Avantgarde, She starts fine when cold; but, occasionally cuts-out when warm and quite predictably fails to start when warm. usually a cooling off period helps.
When she fails to start she will crank and usually try to fire-up, often running very rough, before 'dropping off'.
This started in the spring and has gradually worsened, she did go to have codes read (reputable independent) and there were some, but not wishing to cast aspersions... nothing immediately helpful.
I have read numerous accounts of similar issues, sadly the majority without clear indication of if it was ever resolved.
Maybe you have previously found the answer or helped someone with this class of problem?
Back in the days.. this would have been either the crank or cam position sensors, frustration caused me to swap these out but no change.
It can be seen that some bubbles are entering the fuel (diesel) line after the filter at high revs, but nothing before, apparently this is normal?
Checked the in-tank fuel strainer, clear, and also had a fuel vacuum gauge on the input to the filter and that looked (sorry no values) OK. No electric fuel pump on her, just HP pump vacuum.
Down to taking advice from people in filling stations when she won't start, some insightful and some just downright obnoxious.
