E320 Inner wing
shirleydrive
E320 w210 1998 61K
Recently removed all the wheel arch liner to clear any debris and to check for corrosion. When I removed the liner from the front drivers side wing I noticed a black cylindrical object with tubing connected to it. Higher up on the inner wing there is a beige coloured box with a cable running from it. Anyone have any idea what these items are??
W210 E320 1998
Thanks, Mike
Did it look something like this on my C class AMG in the pic? If so its something to do with the vacuum system, manual headlight level, rear headrests if yours collapse down at a press of a button. Possibly the A/C but I'm unsure of this as I think the air for this is supplied from the PSE pump.
Thanks Andy. Yes the beige box with cables looks exactly like box at top of inner wing on your pic. Will look into your suggestions.
The black cylindrical object was mounted lower down.
Mike
Does this picture help you?
