jshodgson
Changed the rear pads and noticed poor mpg on a long run so checked temp of discs and rear o/s was 120 degrees whilst the other 3 were about 60. Then the ESP light came on and a warning that the run flat indicator was inactive.
On idle the warning light won’t come on. When you press the brake it doesn’t come on. When you release the brake pedal it comes on.
I replaced both the guide pins on the hot wheel as one of them was deformed and noticed the pad had come away from the piston as the clip that holds it in had popped off. I put it back on refitted everything but still have the problem.
Any other ideas of what I could check? Before I changed the pads there was no issues at all and the ESP light came on about 250 miles after I fitted them so not sure if it is just coincidental that it happened when I changed the pads or if it has come on because of the pd change.
