PR1
- Mar 24, 2013
- E320 cdi
Hi, I have a 54 e320 s211 which is causing me quite a headache. I have a recurring fault where I get esp and abs warnings and the glow plug light wont come on and the car wont crank over. This has happened several times over the last couple of years. The AA have been out to it some of these times and have not managed to start it. They plug in the diagnostic machine but the car will not talk to them! I once sorted it by disconnecting the battery for a while, but this has only worked once. It has been to mb but has always started working again before they look at it!!. Happened again last week and this time was still broken when it got there, they said the ecu would not talk to the sam unit, so the sam has been replaced. I have had it back one day only and has broken down again. this time there are also coolent warnings, srs, and although it wont start there is a click or clunk but still wont crank!! I had an unrelated fault that turned out to be a soldered joint in the loom that had corroded, is my wiring falling to bits? Any ideas would be great. thanks
