aka$h
Im doing a twin turbo conversion on my e320c,
Before fitting the kit on, Im totally rebuilding the engine, and gearbox. The diff will be sent to quaife in the hope they can fit a LSD in place.
To further complicate the issue I decided to swap the 4sp autobox for the 5sp autobox.
this is the progress so far.
Engine and transmission being removed from donor car:
Exhaust off
The next task was to remove all the wiring for the 5sp box. For this most of the dash had to come off:
And all for this:
We had hoped the wiring loom for the gearbox in the engine bay was seperate
Upon close inspection this was found NOT to be the case. In fact the transmission cables were part of the inboard wiring harness, as the donor car did not have aircon, it would not be possible just to swap them over. As a result we had to strip the loom right down:
After 2 hours of messing around the loom was seperated
Next step was to remove the rocker cover and strip it down, ill be having it powder coated while its off.
Head off:
Now ready to remove the pistons:
Well thats it for now, the pistons will be off this evening.
Exhaust off
And all for this:
Head off:
