Hello to all, first post having been running 99 E300td for many years with no significant issues 200k due up in 30 miles. Due a glow plug replacement very soon as difficult starting becoming an issue even with improving temperatures in the morning. However---------------------
I have purchased a 2000 320cdi with a fueling issue. The car has 126k and had come in for the injectors to be reseated and re-sealed as the car had suffered the "black death". The injectors were reseated and sealed and the engine restarted and ran under test well with good throttle response.
It then cut out and since then will not restart.
Works completed since non start.
Fault codes cleared down. (None significant to existing faullt)
All nylon fuel lines replaced.
Fuel filter replaced.
Tank drained and fresh fuel added (car had stood for 3 years prior to injector work)
Tank Filter replaced.
Main fuel supply line blown through to tank. (no obstruction).
All fuses checked and cleaned.
Temporary fuel supply hooked up to filter from diesel can and very limited fuel pick up observed.
Air in nylon hose on elbow of line to HP pump not moving under repeated cranking.
No visible leaks and all nylon fuel lines connected correctly
Suspect HP pump but do not have Star test equipment to confirm.
Any advice greatlly appreciated
Many thanks
Adrian
Many thanks
Adrian
