Today I started to tackle a couple of leaky injector seals on my W210.I have new seals/stretch bolts,injector grease and a tap from Hudson precision to clean up the threads.
I soaked overnight in coke and took it for a run to heat the engine and have spent the past couple of hours wiggling the injector from side to side it seems to me moving a small amount but won't come out.
My question is this,I have a Laser 3 piece injector pulling set and have used the window socket to remove the solenoid and little spring from the top of the injector-is it ok to dismantle the cdi injectors in this way?
