E350 Coupe manual gears sport mode
johny5_uk
in a house
E class
Wondering why I spent so much on a car when I don't really do that many leisurely private miles I thought I would take it out today for a spin.
The car was in at Mercedes last week for a response/delay in the throttle when setting off in auto mode (This is only after the car has engaged in a gear higher than 1st and then come to a total standstill but works fine in manual and sport/auto sport/manual). The service chaps are going to speak to Mercedes technical in Milton Keynes after I showed them the fault on saturday but the short term solution was to drive around in sport mode. They also said the car would not use anymore fuel in sport mode :crazy: .
So, out I went and found some country lanes to blast through with the first long term experience of the "manual shift sport mode".
I hadnt really booted it until today, running all through the gears without any interaction from myself. I thought that it would hit the rev limiter and not go any further but I did wonder how you knew when to change gear especially when the v6 3 litre diesel didn't growl at you like a petrol car.
I was pleasantly surprised when I quickly found out that in manual, you can just boot it and not worry about the gears at all. The car pulls out every last drop of power using the full rev range and automatically changes just before red lining. Likewise when slowing down, it pretty much knows what gear to be in.
So I figure my car really has 3 driving modes:
1. auto comfort (sticky throttle like treacle)
2. auto sport (dramatically increased response and power although sensible gear changes when you want to drive casually)
3. manual sport (using the full rev range, peparami? - an animal :D)
Yes, purposely missed off manual comfort, I cant think when I would ever use that.
I checked the manual to see if it said that driving in sport-manual with your foot flat to the floor when accelerating from standstill was ok, obviously it didnt say anything about it but I take it this is ok?? :rolleyes:
I pretty much use mine in Sport mode constantly. The flappy paddles are great for engine breaking then as you said, you can leave the car to go back to auto on its own accord.
Have you tried just running it in manual mode and pressing the accelerator to the floor, not touching the paddles at all?
No, actually I haven't. Is there much of a difference? I have used the stick to change gears, but by and large I just leave it in auto (in Sport) and let the car take the strain.
I did take it to MB World and discussed the delay in pulling away, but they just told me that's auto's for you and fobbed me off...
Try it! there is a lot of difference as the car uses the full rev range :D
I thought when you were in manual, it was exactly that. but I guess its semi automatic? or whatever they call it.
Just try it on a clear road, press sport, then select manual, then from start just boot it up to about 60 (ish :) ). The gears change perfectly, likewise when slowing down, you dont need to change gears, it does it for you.
As for the pulling away issue, if you have all the updates on the same as me then try the following:
1. Standard Auto mode - accelerate to above 20mph (the gearbox must get out of 1st gear) then come to a complete standstill . Now set off = DELAY on accelerator.
2. Standard Manual mode - accelerate above 20mph then come to a complete standstill. Now set off = FINE
3. Sport Auto mode - accelerate above 20mph then come to a complete standstill. Now set off = FINE
4. Sport Manual mode - accelerate above 20mph then come to a complete standstill. Now set off = FINE
This shows that they need to copy a setting from the other modes onto the standard auto mode. I let a mechanic take my car out with me and let him feel it first hand.
The strange thing is, there is no delay when you first start the car OR when you dont come to a total standstill.
Mine was so bad the other day when joining a roundabout. I leave plenty of time but when I pressed the accelerator it felt like the world was in slomo! the car didnt move and i turned my head to the right watching a car coming towards me! felt like a couple of seconds.
