Zain Leics
I would consider taking the vehicle to a different MB retailer. You should not have try to do the work for them in determining where the problem is! Im sure this all whole experience has detracted from being able to enjoy the 43!
I have an E43 w213 (Jan 17) which I bought second hand 1 year old. Does anyone know whether stop start should work on a regular basis? I did two really long over two hour journeys at the weekend. In the middle of the second journey there was a twenty minute queue and the stop start didn't operate even when I switched the ac off. At the end of the trip it started working but one short journey later and it doesn't again. Just been given a loaner c class whilst mine is in again for other issues and the stop start on that works all the time.
I know stop start can be annoying but I don't want to ignore it if there could be an underlying issue. Or maybe other e43s are the same?
From my searches so far the AGM ones are for large engines where there is a lot of energy required and there are non AGM options even then. Also the charging with the ctek is a different option and a higher voltage than the e class manual recommends. Thanks1. As far as I know all Stop/Start main batteries are AGM.
2. As previously said, keep in mind that the battery that needs replacing might actually be the auxiliary batteey, i.e. not necessarily the main battery.
Thanks yeah I'm sticking with them only because I bought it from them and so if there were something not covered by warranty it would still be covered as an issue in the first six months.I would consider taking the vehicle to a different MB retailer. You should not have try to do the work for them in determining where the problem is! Im sure this all whole experience has detracted from being able to enjoy the 43!
I'm sure I've read yours then. I did initially have battery being drained by a fault so I assume there's no more. It doesn't seem to drain when not being used any more. Mercedes me only says charged after a very long journey or full(non agm) charge with the ctek and then one short journey later says partly charged.Do a search for my Mercedes Me problems,you appear to be going through the same Battery Discharging as I was
My 2013 C-Class W204 has a 1.6L engine and an AGM battery.From my searches so far the AGM ones are for large engines where there is a lot of energy required and there are non AGM options even then. Also the charging with the ctek is a different option and a higher voltage than the e class manual recommends. Thanks
It wouldn't be able to interrogate the make or capacity of the battery, just whether charged or not. When I look up batteries for the e43 there are a variety available. As mine is an early build I'm imagining that they may have changed their minds afterwards...
