kamkamkam
Hi folks,
I flipped my driver's seat forward to get to let someone out of the back, the electric motor moved the seat forward and when I flipped the seat back, I found that the base did not move back although the motor is working. The base is stuck in the forward position and I can see that a cable connecter has got itself caught under the bracket that holds the motor, and it has popped the motor out. However the cable connector is stuck and I cannot put the motor back in position. Does anyone know how to either move the seat manually or even remove the driver's seat to release the cable connector? Thanks.
