- Nov 29, 2002
- Location
- London\Essex
- E63s s213 2019, E55 2004 Silver-SOLD, E63 w212 Weistec AMG-SOLD, E55 2004-SOLD, C36 1997-SOLD
After a major disappointment at the EC Dyno day when power on the car was failing at 5500rpm, early indications was it was a fuel delivery issue.
After doing alot of digging around and most things leading me back to the fuel pumps, i pulled the seat bases up and removed the bolted covers to find this, main fuel pump cover was leaking
after removing the plug you could see the pins meltingthe plastic and thats where the fuel was getting in from. Melting was from one or both of the fuel pumps drawing too much current and heating the pins
So I ordered a brand new set of pumps from MB and after reading various threads and WIS docs attempted to get them in.
the procedure was tricky enough without taking photos so i only have a few, loads of pipes and wires with the added fun of petrol!
[/URL]
you can see the nice clean filter which looks like a teabag in the new pump
You can now see the black clogged up filter in the old pump, this probably led to the death of the pump as it had to work harder to deliver the fuel
the car drives totally different now, MUCH more power and freely revs up to 7K revs no problem.
dont know why MB put pumps in that had in built filters especially for a car that consumes so much fuel in the first place!
another problem solved, not a cheap one either!
