Evening all,
RE : E55 1998
1.Finally decided to work out what could be up with the brakes tonight. The brakes are fine on very light application. medium application of brakes and the car and wheel shakes as if abs is engaged. Seems to get worse the hotter the brakes are (or the faster you are braking from i.e. 100) . When I heavy brake it goes away, and the car stops no shaking or drama.
Brake assist issue or just warped brakes ?
2.Has anyone had a Mercedes Geometry check, do they check all settings ? Good experience ? Any recomended dealerships ?
3.My car has a blue tint to all the windows and passenger mirror, is it supposed to had a blue tint on the drivers mirror?
4.(GRAV888 ?) Has anyone changed the middle silencer on the exhaust for straight through pipes, if so have you got the details ?
Thanks for reading and drive safe
Cheers
Ian
RE : E55 1998
Cheers
Ian
