E55 k steel liners
WG M-B
Auhorised Forum Sponsor
N/W london
C63 Wagon in black
Any members or other indies done this????
I'm curious if it will be ok
I have a 211 in at the moment that needs new liners. I'm not aware that the silicone aluminium liners can be refurbed so to speak
And if they could is it really worth it or should I just go with standards liners?
Obviously the aluseal is just a coating, but can it be refreshed
Cheers
OP
OP
W
WG M-B
N/W london
C63 Wagon in black
Maybe this should be moved to the AMG section?
BFT
Guest
SL55 AMG
Darton make the sleeves for them if that helps.
E270 Owner
S E London
Anything I get my hands on.
If you use steel liners you need different rings to suit.
The original ones can be polished so long as they are still within tolerance.
Sunnen processing is usually good enough for the bores to be refurbished.
C36fan
Kent, UK
‘15 C63, ‘15 CLS63, ‘01 E55, 01 ML55 ‘16 Vito 119CDI
Are they replaceable ?
OP
OP
W
WG M-B
N/W london
C63 Wagon in black
This is the question. I have had a quote from my local engineering shop to convert the block to steel liners. But ideally I would refurb what is originally there!
I have been quoted 225 plus vat per pot :eek:
C36fan
Kent, UK
WG M-B said:
This is the question. I have had a quote from my local engineering shop to convert the block to steel liners. But ideally I would refurb what is originally there! I have been quoted 225 plus vat per pot :eek:
so ask them to measure them to find out how deep they have to go to get them in good order an then find out if mercedes do oversized pistons to match it .
If that was a cast ion block I wouldn't have a problem to put new liners in it but being a alloy one I rather oversize the bores .
OP
OP
W
WG M-B
N/W london
C63 Wagon in black
It's not the issue. They are coated liners
C36fan
Kent, UK
let me contact a friend in Texas he rebuilds a lot of these and I'll ask what he normally does!
C36fan
Kent, UK
E270 Owner said:
You can fit iron liners with oversized pistons and rings its quite normal to do this for some engine re-builders. If the original bores just need polishing and are not damaged (within tolerance) then its cheaper to use Sunnen process. http://www.sunnen.com/NewsDetails.aspx?NewsID=11 .
my mate said the same and he do them every day!
C36fan
Kent, UK
He said do the steel liners and use weisco pistons they will come with the appropriate rings!:)
E270 Owner
S E London
When we buy liners they come with matched pistons and rings, just depends on the manufacturer as to whether we use forged or cast,
and the cost of course.
C36fan
Kent, UK
E270 Owner said:
When we buy liners they come with matched pistons and rings.
are they not pressed liners made by a machinery shop?
E270 Owner
S E London
Various way to get it done to be honest, the most popular way is for me is to Sunnen the bores and use Mahle piston/s where necessary.
Darton liners with Mahle SLR Pistons on the E55 would be an option.
All depends on the £$£$£$£$£$£$ available.
OP
OP
W
WG M-B
N/W london
C63 Wagon in black
The car came in consuming oil. A cylinder leakage test showed no issues so we put it down to the inlet guides/ seals. On removal pots 5/6 were cracked right at the top. I'm not sure how deep, but I think from looking it really is only the coating.
The car is a 55k estate with 150 on the clock but utterly gorgeous in every way. I'm trying to weigh up wether it's worth buying and repairing.
Alps
London\Essex
E55 2004 Silver, E63 Weistec AMG(SOLD), E55 2004 Silver(SOLD), C36 AMG 1997 (SOLD)
speak to Acid @MSL, he has done a few of these and should have the contact for you.
E55BOF
South Bucks
S211 E500, SLK55, FJR1300, Caponord
Ulp!! I have an E55K with 136k on the clock now. Is this a common problem? I do hope not....
