E55 lowering links?
smoothcoupe
WEST YORKSHIRE.
MERCEDES E55K-2001 AUDI S8-MERCEDES 300CE 24V SPORTLINE
hi all I’m after some good quality lowering links for my 2004 E55. Seen ones on ebay ranging from £75 to £300. I want top quality ones that won’t rust and seize.. and how hard are they to fit!??? Any advice please
Fronts are easy to fit but the rear is a pig located above the diff. I'll be honest and say get your indy to fit the rear one.
I won't recommend the ones I have as they are a bit pitted after 3 or more years on the car, but the anodised ones look good.
It takes a while to get the set up how you like and be careful about going too low at the front. It put my headlight aim out that needed recalibrating for the MOT.
If I were to do it again I think I'd get it done on Star and forget about links.
tbh, once setup you wont be fiddling with them again! also they cant really be seen, id go for a cheap set.
As above, they aren't visible so just cover them in clear grease if you want to protect them.
