I think there was a bit too much advertising going on by MSL, at least that was my thought before his posts got removed!
The biggest problem with the A class are the gearboxes. Try and buy a manual one if you can because if you get an auto and it goes wrong the box is £5000 from MB and you will be had pushed to get a decent second hand one from a breaker. Most of the ones they have are there because they have been scrapped due to the gearbox.
Sorry, but where did you get that figure? An auto box for one of these is closer to £2k and not that prone to failure.
They do, however have various other problems with them:
Rear suspension radius arms
Air mass sensor (part of the ECU £1k roughly)
Rear springs
Steering column
I'd steer ('scuse the pun) clear personally
