Easy Entry Function
Merlin13
Hi All,
I wondered if you could help me please.
I have set the convenience function on the dash to turn on the easy entry function (steering wheel out the way and seat back) but nothing ever happens then I get in or get out of the car! Am I doing something wrong? Oh its an '05 SL 500 btw.
Thanks for your help.
J
It will only move the steering wheel and seat out of the way if it has too. If it is already set with the seat back a long way and the steering wheel up a long way it won't bother to move them.
Try setting the memory with the seat close to the dash and the steering wheel right down and programme it in and then see if it works, at least you can then tell if you have a problem or not.
if your car has a lever to adjust the position of the steering wheel then try twisting it as thats what you have to do on a CL...
