Hi Gnasha,
Did you end up buying this and giving it a try?
I've just started looking at the best way to access data from a 38 pin connection - I've got a year 2000 CLK.
I'm not over confident that the products I've seen on ebay will give comprehensive information...
I was wondering if a Star diagnosis tool would be within your budget but even a clone does not seem to fit in.I don't mind spending more on a solution that
- Will definitely work with my car
- Will give access to as much data as possible
- Will work with any other car I might have in future
But of course would prefer not to spend many hundreds of pounds - probably not be worth it for the limited use it'd get.
Matt, you can come try mine if you are not too far away.
Infact, I could try in on a CLK55, but the owner is away at the moment.
http://www.mbclub.co.uk/forums/general-discussion/113139-obd2-socket-adaptor-ebay-code-reader.html
Whitey
