Hi, the link to the online EPC WIS and ASRA is here:
http://www.service-and-parts.net
This is now the only place you can get Mercedes workshop tools too
Same here, never have any problem in obtaining the tools I need.I get all my special tools straight from my dealers. Is there a restriction?
I don't see why the real discs would be difficult to install and would stop working if you know how these are supposed to be used. After all, these have to be 100% running at workshops too.
The software is intended to be run on a networked workstation, not a standalone PC. When I installed my copy I had to use the Microsoft loopback adapter to get it to work. Having run fine for a couple of years it now hangs for several minutes then comes up with several errors in German then "Microsoft Visual C++ - debug assertion failed".
I haven't had the energy to try and fix it yet, I presume de-installing and re-installing would do the trick.
Is it possible to get the email of the seller without registering with ebay? I would give it a try and report back.
