Callipers stay in place. Pins out, pads out, pads in, pins in.
Are you doing this yourself by the way?
Just to clarify - OP has an E55, they're different pads/calipers to what all you guys have - in theory all pads should fit properly out of the box..
However, in the real world this isn't always the case. The (aluminium) Brembo 8-pot calipers have four brake pads each at the front. The inner face pads tend to get stuck anyway (even OE) as the stainless guide plates move out away from the calipers due to the corrosion of the alloy calipers. This causes the pads to be too tight and hence they don't move freely.
The EBC pads may or may not be a smidgen different in dimension to the OE pads. Even half a millimetre could cause a usually tight fitting brake pad to be too tight to fit.
Alps used these EBC pads on his E55 and said he had to file them down a bit to fit. If they need filing down it will be on the sides - but until you go to do the job you won't know if they need it or how much. Maybe as simple as a thicker paint coating on the sides or as much as needing a mm or two shaved off for a proper fit.
I'm sure he'll be able to advise how much he needed to remove but as I say you'll need to remove the old pads and see first before doing anything
And as above - just the pins need to come out - the caliper can stay in place if you're not changing the discs.
You'll obviously need to remove the wear sensors though
PS - order new pins. And have a hacksaw ready just in case be ready for a fight!
I did my own E55 (albeit a few years back now) and changed all the pads. As Will says, 4 per side, though I didn't have to do any fettling with the new ones.
My only concern was the SBC system, so the car remained locked and the key out of the way.
Red stuff are lawful, get yellow stuff from EBC direct. They fit straight in. I put yellow stuff in my mates E55 and genuine MB in mine, same fitment
I had YellowStuff in my M5. NEVER again. My wife's Twingo felt better.
Funnily enough, that's usually the response from Nissan owners on the subject of Redstuff. - Never had a problem with Yellowstuff myself.
As Will said ; its the thicker paint on the metal plate the pads sit on and any corrosion that pushes the steel calliper plate out which causes the tightness.
you will see where its tight and just file a bit there.
new calliper pins defo and spray the old ones up with penetrating spray a few hours before attempting the job
