navaidkhan
- Mar 10, 2005
I have a A140 Mercedes with around 56K mileage in reasonable condition recently purchased. I noticed a problem - when you start the car it cuts off - I thought it might need some tuning but when I took it to Mercedez, I and was shocked to find out that I would need to spend around £700 to install a new ECM or some control unit with a problem with Mass Air filter. I received a diagnostic report from them which stated in their opinion that I need a the whole unit...!!!
Any suggestions would be greatly appreciated!!
Here is the output of the report from Mercedez
Control Unit: ECM1
MB number: 0265450532
Supplier: VDO
Hardware status: 00/00
Software status: 14/98
Diagnosis ident.: 3/01
ECM1
Fault Memory
P0500 CAN: front and or/ -002 rear vehicle speed signals implausible
P1681 crash signal -002~+
P0703 Read ETC ESP fault memory
P1681 crash signal detected -001
P0600 CAN from ESP -001
P1681 crash signal -003 implausible
P0100 Hot film mass air -002 flow sensor (B2/5) Air mass too large
P0100 Hot film mass air -002 flow sensor (B2/5) Air mass too small
P0170 Self adaption -002 too lean
P0121 Actuator (M16/6) -013 actual value 1, 2 potentiometer implausible
Control Unit: ECM1
Supplier: VDO
ECM1
Fault Memory
