Out with the meter today main battery 12.3, running 14.4, car has been sat for the last four days, will give it a run tomorrow and retest... lol still cant find the aux battery
Its in the boot, under a cover on the right hand side.
Mine is in the boot under the boot carpet to the right of the tyre inflating stuff.
Don't really like the stop/start but understand why it's fitted. I also switch it off 99% of the time, use it in traffic jams and last summer in a jam, switched it on. I found that after 5mins approx, the engine restarted its self. Had only the radio on and as it was day time , no need for lights. So, not very impressed with S/Start but happy that the ECU saw a need to restart the engine, I expect it saw low volts in the battery.
Had the same problem with my 2012 B180cdi, until I replaced the battery, one very expensive gell battery later the eco system now works every time, It would appear that it will not operate with low battery voltage or amps available to crank the engine
How I believe it works, the ECU controls the smart alternator via the negative rail battery sensor on the main battery, the ECU reads via the sensor the battery State Of Charge and allows it to go down to around 80%, this is to allow room for any overrun or brake regen to occur at a high charge rate without damaging the battery, this is why a little used or older battery which still has years of life left appears not to hold a full charge, unless there is ample opportunity for regen to occure the main starter battery is rarely anywhere near fully charged. If the battery reaches a SOC of near 100% the CPU stops the alternator putting any further charge into the battery until the SOC of battery is again down to around 80%. Don`t change the battery just because stop/start does not work, total waste of money in my view.
