Eco stop/start.
Discussion in 'Electronics' started by Sheffield Col, Oct 21, 2018.
  1. Sheffield Col
    Sheffield Col Active Member
    184
    Sep 16, 2015
    Sheffield.
    Car:
    Mercedes 2014, C Class 220 Diesel Automatic Blutec W205
    Hi, the eco stop/start doesn't seem to be working, is this anything to worry about. Or is there a "fix" for this ? Car is W205 C class C220 Diesel Blutec.
  2. KillerHERTZ
    KillerHERTZ Administrator Staff Member
    16,936
    May 21, 2003
    Cambridge
    Car:
    CLS63 AMG
    Your battery might be getting towards the end of its life.
  3. OP
    OP
    Sheffield Col
    184
    Sep 16, 2015
    Sheffield.
    Car:
    Hi do you know where the battery is ?
  4. ioweddie
    ioweddie MB Enthusiast
    1,356
    Sep 16, 2012
    Winford Isle of Wight
    Car:
    AMG Line Premier Plus Estate C220d
    C43AMG likes this.
  5. st13phil
    st13phil MB Enthusiast
    8,010
    Nov 6, 2007
    North Oxfordshire
    Car:
    His - Denim Blue A220 AMG Line Premium / Hers - Obsidian Black R172 SLK55
    While your problem may be a tired battery, the reality is that there could be a myriad of reasons why your stop/start isn’t working.
    Another truism is that unless there’s a definitive stored fault code, you may struggle to get it fixed. The start point as always though is to get the car on Star Diagnostics to see if there is a fault stored.
  6. OP
    OP
    Sheffield Col
    184
    Sep 16, 2015
    Sheffield.
    Car:
    Doe's anyone know where the auxiliary battery for stop/start is located ?
  7. Larkone
    Larkone Active Member
    621
    Jun 13, 2016
    Essex
    Car:
    2008 CLS 320 CDI facelift
    Doesn't your manual tell you? We won't rat on you if you open the manual but do it after dark to be safe.
  8. jmarkha1
    jmarkha1 Active Member
    69
    Aug 29, 2017
    Wiltshire
    Car:
    s212 e350 AvantGarde
    My start stop "stopped" working - charged the battery one Saturday - it worked afterwards for a few weeks. In my case I think the batter(ies) are probably not at their best. New batteries on the xmas list :)
  9. Petrol Pete
    Petrol Pete MB Enthusiast
    3,498
    Nov 11, 2016
    Petrol stations ...everywhere
    Car:
    C55 AMG Wagon
    The stop start function not working must be a bonus, right ? It's pretty pointless and may have already cost you the price of a replacement battery.
    PeteTheOldGit and classiccarzone like this.
  10. 190
    190 MB Enthusiast
    3,061
    Mar 4, 2015
    Cheshire
    Car:
    2009 W204 C180K
    When I'm walking the granddaughter to school in Marple, the traffic is a nose to tail crawl. I often see cars barely come to a halt before setting of again 1 or 2 secs later and still the stop/start kicks in. Seems crazy that it doesn't wait longer to be sure the car has really stopped at traffic lights or similar. At that rate the stop/start must kick in dozens of times per mile in traffic. No wonder It can be hard on the battery.
    If I had stop/start I'd want a little knob that allowed me to adjust the interval before it stopped. A bit like variable intermittent windscreen wipers.
  11. Daveuk
    Daveuk Active Member
    261
    Apr 1, 2018
    Barnsley
    Car:
    A180 Sport & E250 AMG Sport
    M5 London, C43AMG and st13phil like this.
  12. 400ixl
    400ixl MB Enthusiast
    1,118
    Feb 20, 2016
    Norfolk UK
    Car:
    E250 AMG Sport Convertible
    The amount of pressure you put on the brake pedal when you have come to a complete stop determines whether it cuts in or not. Anyone half competent in controlling a car can sit stationary with stop / start on (and green) and not have the engine cut unless they want to.
    Ted likes this.
  13. Ted
    Ted MB Enthusiast
    5,730
    Feb 26, 2004
    Bourton on Dunsmore
    Car:
    SLC 250D AMG Line, Yamaha XVS 1100, Jeep Renegade
    Yes, I’ve found that this can be done on the level with a bit of practice. This gives a goid extra level of control.
    Easier in a manual where you just keep the clutch in when you don’t want the stop/start activating.
  14. markjay
    markjay MB Club Veteran
    24,638
    Jun 24, 2008
    London
    Car:
    W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
    As others said, the most common cause for the Stop/Start function not working is an issue with either the main battery or the auxiliary battery (on my W204 the auxiliary battery is in the spare wheel well in the boot, but the location can differ from one model to another).
    In most cases where either battery is at fault there are no fault codes showing on STAR, and the only way to diagnose the issue is by process of elimination, i.e. replacing either or both batteries.
    Said that, as others pointed-out, there are very many other components that can fail and cause the Stop/Start to malfunction. This includes components in the battery circuit or charging system that are external to the battery itself. So a STAR scan is always recommended before proceeding with battery replacement.
  15. OP
    OP
    Sheffield Col
    184
    Sep 16, 2015
    Sheffield.
    Car:
    looked in the manual but there is no info as regards its location.
  16. Gallon
    Gallon Active Member
    80
    Mar 14, 2010
    UK Essex.
    Car:
    2015 S205 C200 AMG Premium Estate.
    Hi. I think you will find that the W205 does not have an aux batt but uses a capacitor which is an electrical storage device. It is located in the passenger footwell area. Mercedes call it a Voltage Converter.
    Remove N/S/F kick panel trim then remove the glove box under dash panel. Next remove the N/S/F section of carpet then remove the plastic panel on the floor against the bulkhead, the capacitor is bolted LHS of electrics panel.
    PeteTheOldGit and elan362 like this.
  17. ioweddie
    1,356
    Sep 16, 2012
    Car:
    I thought it was in the luggage area of my S205
  18. Gallon
    80
    Mar 14, 2010
    UK Essex.
    Car:
    Just had a look on EPC at a few W205 models. Under Electrical /Battery it shows only 1 batt called starter battery in engine compartment. Whereas if I look up my car a S204 it shows 2 batt's, main battery in engine compartment & aux batt 12V/12AH in luggage area.
  19. jmarkha1
    69
    Aug 29, 2017
    Wiltshire
    Car:
    New Battery fitted today - ECO indicator green - first time for a while.
    I usually turn it off anyway but a good indication battery was tired...
    markjay likes this.
  20. Gazwould
    Gazwould MB Enthusiast
    1,746
    Sep 29, 2018
    Everywhere
    Car:
    S204 C250 CDI AMG Sport
    Year and mileage ?
Share This Page
