geraldrobins
- Jan 26, 2013
- VW Golf, past c200cdi
Surely the main stress for a timing chain is opening the valves which are heavily sprung, so its under load whenever the engine is running?
The main stress is starting, as in moving the entire engine internals from a static position to running while overcoming compression.Surely the main stress for a timing chain is opening the valves which are heavily sprung, so its under load whenever the engine is running?
I'm not an expert but I'm not convinced. The starter motor overcomes the compression and the timing chain is under continual stress opening valves?The main stress is starting, as in moving the entire engine internals from a static position to running while overcoming compression.
Once running, the camshafts open the valves and leverage comes into play.
This is one of the reasons why engines with stop / start have auxiliary (or main) electric oil pumps that maintain pressure when the engine is stopped.The only mechanism for additional timing chain wear I can think of is if there is a hydraulic chain tensioner actuated by oil pressure it will take a finite time to tension the chain after every start. Unless of course that problem was engineered out when stop start was introduced.
I think there's a common misconception here. The camshaft is driven at half-speed from the crankshaft, so as far as the camshaft drive is concerned, it doesn't care whether the crankshaft is being turned by a starter motor or by combustion above the pistons. The load on the camshaft drive is caused by the cam lobes lifting the valves against (primarily) the spring tension that keeps them closed, i.e. it's nothing to do with cylinder compression.The main stress is starting, as in moving the entire engine internals from a static position to running while overcoming compression.
Can you please explain the wear mechanism?
I've seen the “engine braking wears out he timing chain / belt” statement a few times, but I’m yet to hear a cogent argument as to why.
Why does stop / start cause the timing chain to stretch (wear)?
Thanks for responding with honesty. I hear the "theory" of stop-start causing premature failures too, but I've never heard a plausible engineering explanation as to why, so I remain highly sceptical.Its certainly a theory I hear a lot.
When a chain "stretches" (in common parlance) it hasn't actually stretched, rather the individual link pivots have worn. For a chain that is properly specified regarding power transmission characteristics that is not the subject of a manufacturing fault, this generally points to a failure of lubrication. This could be a result of insufficient lubricant delivery due to an oilway being blocked, inappropriate oil being used, contamination (diesel engines are poor for this), or simply running the oil for too long.Mine did make an awful rattle at start up and it was found to be the chian had stretched in a couple of places along its length.
Hopefully now it's been replaced you can enjoy the car without further premature failuresThe rest of the car and engine are in tip top shape though so I was just unlucky.
Thanks for responding with honesty. I hear the "theory" of stop-start causing premature failures too, but I've never heard a plausible engineering explanation as to why, so I remain highly sceptical.When a chain "stretches" (in common parlance) it hasn't actually stretched, rather the individual link pivots have worn. For a chain that is properly specified regarding power transmission characteristics that is not the subject of a manufacturing fault, this generally points to a failure of lubrication. This could be a result of insufficient lubricant delivery due to an oilway being blocked, inappropriate oil being used, contamination (diesel engines are poor for this), or simply running the oil for too long.Hopefully now it's been replaced you can enjoy the car without further premature failures
My only experience of chain stretch on a Mercedes Benz is with the old 190E. At circa 40,000 miles there was an awful chain clatter at start up and sometimes at idle. I paid for the chain to be replaced at an MB dealership only for the clatter to return circa 10,000 miles later. Luckily for me, MB UK took care of the second replacement including the replacement of a modified (improved) oil/lubrication system. Following that replacement I didn't experience any more chain stretch issues right up till when I sold the car at circa 130,000 miles
And regardless of the lessons learned back then, they started fitting single chains again, and too make it as awkward as they possibly can, they fitted them to the rear of the engine and not the front where you had easy access.Was yours an early 190E. They had a single row timing chain which was known to be a problem. It was replaced with a duplex chain somewhere around 1988/89.
No your not wrong, easiest way to understand it to liken it to moving a static object.I can see the logic of why repeatedly pulling the chain from static position into motion can cause it to stretch over time (regardless of who or what does the pulling).
Said that, I also acknowledge that my view of this isn't very scientific... it's more of a 'bloke in the pub' opinion
So I may be wrong.
I think you’re being a bit naive if you think stop start doesn’t damage the engine in anyway ....TonygwYou have most likely just been unlucky with an early failing part. Tensioners have always had a variable life across pretty much all brands be it on belt or chain driven cars, just like chains themselves. Sometimes these things do just happen.
There are thousands of taxis that are on stop start all day everyday doing hundreds of thousands of miles. There is no rumour mill or otherwise of these falling foul of stretched chains. Spoken to a few indies who maintain taxi fleets and not one of them had any concerns about stop start causing any issues.
As for that story from a Bentley foreman, what a load of generic BS. Yes there are failures with mechanical parts all the time. Turbo's are far more likely to fail if driven hard and then just shut off. However most cars have sensors now and keep the oil flowing to them if shut off and over temperature. So stop start will make absolutely zero difference.
Totally understand that some people don't like like the idea and switch it off and I'm glad there is a way for them to do so.
