ronniecavs
- May 9, 2010
- 2004 c200 cdi
Hi all
my c200 cdi failed emissions test, I i scanned with carsoft i980 and had dtc p2511 egr monitoring malfunction
i could see that the egr valve was at 56% while sitting at idle , All information I can find says it should be closed at idle ,I have removed egr and cleaned then refitted and watched it with the end cap off
as soon as I start the engine it opens , and shuts again when engine stopped, so it appears to be working mechanically opening and closing and not stuck
so Im thinking it could be a bad sensor or air leak on on intake and not a bad egr
heres the scan results with engine idling
Rail pressure 320.60 bar
pressure control valve 24.40%
quantity control valve 39%rpm 780
injector quantity 11.66
atmos pressure 1008
air mass 348.80
egr 56%
intake pressure 997
boost pressure 1010
charge pressure position 95%
does this look normal or point to any thing out of whack
any help would be most appreciated
kind regards
Ron
atmos pressure 1008
air mass 348.80
egr 56%
intake pressure 997
boost pressure 1010
kind regards
Ron
