EGT gauge.
Discussion in 'Engine' started by Dieselman, Nov 26, 2008.
  1. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Peugeot 403 Convertible
    I've been meaning to fit an EGT gauge for a while just to see what the temperatures are in standard trim.
    Also as my car doesn't have a fuel computer I thought it would be good to use as an indication of how much load the engine was under so would indicate how much fuel is being used, much like a vacuum gauge does on a petrol engine.
    First the probe needs to be installed poking into the exhaust manifold so...
    Manifold and turbo need to come off.
    Note the nice swept shape of the manifold, this gives good gas flow.
    [​IMG]
    Part the turbo and manifold.
    Note the turbo intake aperture is larger than the manifold exit aperture. This restricts and disturbs the airflow into the turbo.
    [​IMG]
    Having decided on a suitable place drill and tap the manifold and fit the thermocouple ferrule.
    This will project through slightly so grind the excess back.
    Whilst at it I decided to create a bell mouth for the gasses leaving the manifold for better gas flow into the turbo.
    [​IMG]
    Install the thermocouple about 1/3rd-1/2 way into the gas stream.
    [​IMG]
    Thread the cable through to the passenger cabin and connect to the gauge.
    I've only been able to do this temporarily for now as the cable is too short, so I've ordered some.
    [​IMG]
    Having taken it for a drive I can say it works brilliantly and is sensitive enough to detect such engine loads as switching the lights or vent fan on...and especially putting the gearbox in gear or turning on the air-con..
    Idling sees temps of about 108c tonight, but 140c earlier when fully warm, and maxxed out up a steep hill gives ~715c and a 777c momentary peak...
    No room for adding extra fuel there..
  2. tuikku
    tuikku Active Member
    155
    Apr 25, 2008
    Finland
    What kind of weather you have there.
    Here are "full" winter already... and snowing.
    10-20cm more new snow this night.
    In warm day, it is very easy to get there 100c more.
    Throttle position is very important.
    More power -> more heat.
  3. maddog
    maddog Active Member
    725
    Dec 18, 2007
    Most people i know fit them in the downpipe after the turbo this may be easier if you dont have a pre cat there
  4. Uberwagon
    Uberwagon Active Member
    753
    Jul 29, 2006
    Car:
    1991 500E
    Just before the turbo will be the highest temp so this is where the probe should be fitted.
    Dave!
  5. BTB 500
    BTB 500 MB Club Veteran
    18,748
    Aug 7, 2005
    Berkshire
    Car:
    R129 SL500, W639 Vito 120, S203 C230
    That's a really useful mod.
    I like the gas flowing work too, probably offsets the very slight additional restriction from the probe!
  6. maddog
    725
    Dec 18, 2007
    Actually the highest temp would be close to the exhaust port , this is where race cars have their egt sensors
    Stuck out in the flow right before the turbo is driven is not where i would put any obstruction , after the energy from the gasses have been used seems a much more suitable place to put the sensor especially if the whole point is to determine how much fuel is being used not exactly running things on the ragged edge on a standard engine
  7. Uberwagon
    753
    Jul 29, 2006
    Car:
    1991 500E
    That is not because they are the highest temperatures, but because they want to know how well each cylinder is working.
    Dave!
  8. tuikku
    155
    Apr 25, 2008
    Finland
    Yes !
    I have been measured that way also.
    That is exactly how happens.
    "Working stroke" is only every second stroke.
    So, sensor get cooler by waiting the second working stroke.
    And, ... there are differences between cylinders.
  9. OP
    OP
    Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    The downstream temp is inaccurate and will be at least 200c lower than upstream so isn't a good guide.
    If I wanted to monitor each cylinder for power balance I would put a probe in each manifold tube but that was overkill for this application.
    Although it doesn't appear so, the probe is set back in the manifold exit and is actually at the widest point of the tube so shouldn't create much restriction to flow.
    As far as running on the ragged edge, the max temp was 770c which is plenty high enough. I wouldn't add any more fuel without increasing air flow first.
    A better intercooler, higher flow turbo, freeflow exhaust, etc will reduce EGT temps, more fuel will increase them.
  10. OP
    OP
    Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    It was about 5c yesterday, today is 10c....:bannana:
    It was your posts that prompted me to get on and install a gauge. Thanks..
  11. lynall
    lynall MB Enthusiast
    3,169
    Jul 31, 2008
    Kent
    Car:
    The silver one.
    If its a k series thermocouple loads on e -bay so you can measure intercooler before and after std and modified, coolant temp in fact anything some of the figures were interesting especially the supposed super duper intercooler:eek:
    Even measuring the air temp in the air box and watching it go up 30 deg as a/con switched on as all that lovely red hot air went everywhere.
    Lynall
  12. tuikku
    155
    Apr 25, 2008
    Finland
    I have measured also intake temperatures, and -pressures, and vacuum before charger.
    Thats why I have in my car as big intercooler as it is possible to fit.
    [​IMG]
    Moore boost gives lower exhaust temps, but is bad for fuel economy.
    And if you donĀ“t have enough big cooler, intake temps peaks.
    MB,s stock coolers are poor.
    Bigger charger gives more air at same boost pressure, and is good for economy (and power :rolleyes:).
  13. paul_f
    paul_f Active Member
    151
    Mar 26, 2007
    Chatham, Kent
    Car:
    2012 W212 E350CDI Estate and 1966 VW Splitscreen camper
    What intercooler did you fit?
  14. tuikku
    155
    Apr 25, 2008
    Finland
    It is custom made.
Tags:
Share This Page
