Darrell
Hardcore MB Enthusiast
- Dec 15, 2006
- Gixxer 6, Citroen Berlingo, 911 C4S, Dacia Duster and lots of bicycles.
I might roll over the odd pedestrian crossing when there are no pedestrians but some of those junctions in London are so nasty I’m safer by obeying the rules.Stuck at the lights? Surely you are not doing it right!
(I jest - cycling is a lot about self-preservation these days)
I saw that a driver was recently fined 4 points and £1000 for overtaking a cyclist too close*. New rules mean you have to give 5ft of clearance, which is good to know.
*Driver fined £1,100 for passing cyclist in Bridgend too closely fine was for actually not paying a FPN but the point stands.
Stupid rules.Amazing....the motorist gets fined for overtaking too close......guess this type of fine make a pile of money across the country.
So an update: I've just converted a bike similar to the solution described in the last picture of post #18.
In the quest for more speed, the only answer is to drive the crank, as that is then geared.
So I've fitted a Bafang mid motor kit to the crank of an old Subway 8 (with the Nexus 8 speed hub gearing) and mounted the battery where the water bottle usually is.
This gives a reasonable center of gravity.
You do need tools to get the bottom bracket apart, and probably the ability to deal with different chain lengths. Other than that, its an easy install.
Short summary - it now has the potential to go too fast, but there are varying degrees of assist you can program into it. It detects when you are pedalling and then activates the motor.
I was impressed with my original conversion (with the powered hub), but this is a different league.
Either seem ok to me.I was thinking about this update too but wasn't sure which system (hub or crank) gives the least drag if you wish to cycle with the motor switched off (or you run out of electricity)?
thanks
That is true. You can buy kits that are locked to these requirements and the other ones can be reprogrammed to match these requirements. eg maximum power can be software limited, and maximum speed can be software limited.I was reading an article somewhere this week warning about DIY electric conversions ... if you don't meet all the specific requirements (main ones being 250 watts maximum power and no assist above 25 kph) they are legally classified as mopeds and can't be ridden on-road without being registered and insured.
If you are referring to professionally built ebikes, then yes, there are a huge range of extremely good and well thought out bikes out there, and I'd have quite happily bought one except for the price! If I was starting from scratch, I'd be looking at getting one on the Bike2 work scheme.Holy Thread Revival, Batman !
But still I wonder, why? All respect to the British Shed tinkering tradition, but aren't there absolutely fabulous things out there which were well engineering to do it all so well, with handling, tyres and braking commensurate with power going through those wheels?
I get it. It’s the British tradition, real men have a shed! That Kalkhoff in 2013 cost me about £900, half its original value, I think. As did its two replacements an e-MTB and a tourer with front suspension.If you are referring to professionally built ebikes, then yes, there are a huge range of extremely good and well thought out bikes out there, and I'd have quite happily bought one except for the price! If I was starting from scratch, I'd be looking at getting one on the Bike2 work scheme.
But spending around £2k on a new bike is not something I was prepared to do, and I already had a cheap conversion (see top of thread) so the improvement in performance for that money just wasn't there.
For a lot less money, I have now resurrected a perfectly good bike - and I like tinkering.
It is apparent though, that bikes are potentially like guitars, hi-fi, <insert hobby of choice> etc in that there are people willing to spend vast fortunes on very small increments that are important to them, and that even £2k is a cheap bike. And like guitars in particular, they breed. I've got two ebikes now, so the old one has been given to another family member.
That Kalkhoff looks like it was a pretty ideal hybrid commuter and was probably perfect in 2013 (what was its price tag?), but was also classified as a moped and even had a bracket for a number plate! The bike in the picture looks great, With the proliferation of potholes, the perfect bike would have a more significant rear suspension I suspect now!
With regard to excercise, I'm still putting in the same amount of effort (based on my wheezing and heart rate), just going faster. It doesn't go so fast that I don't need to pedal. I didn't want a pseudo-moped!
