blue190
- Mar 12, 2006
- Location
- Crowthorne, Berks
- Birthday present - 94L 190e 2.0 in Black, 88F Volvo 740 auto estate (only for towing!!)
Hello to all you fellow MB owners/drivers.
I have recently purchased a 1992 190E 2.0i. It has 200k on clock but has 6k on the recently fitted new (not recon) engine. Having not owned or really driven a merc before i was quite unfamiliar with its quirks and began to get alarmed when the temp needle started rising quite quickly in standing traffic. So this weekend, thinking there was a problem, I broke out the trusty Haynes manual and set about checking the obvious things. It turns out i was being over cautious and it can run at that temp, and the fan works at the proper temp and turns off similarly. One thing puzzled me though, as well as the Electromagnetically coupled pulley driven fan, there is an electric fan on the outside of the radiator(in relation to engine bay), to which the Haynes manual makes no reference(not in the cooling chapter anyway). Could someone enlighten me as to why i have it fitted and whether the engine needs to get proper hot to make it kick in? The car does have aircon fitted, so is it someting to do with this? Thank you all in anticipation of your help.
